cudaracer
I have a mechanical pump with a fuel line hugging close to the block/intake, and a rubber hose (approx 3 ") connecting it to a cheap clear fuel filter, than another rubber hose (approx 12") that runs up to the brand new 600 eddie carb inlet.
So once the engine warms up, or gets hot, and I shut it off, it takes about 5-10 min and all the fuel runs out, as evidenced by the clear filter being empty, and I have to pump it all back in with the starter motor. Pain in the freaking arse.
Anybody know why?
I am about to reroute everything, eliminate the cheap filter and add a new fuel pump and replace the filter just prior to the pump. Should take care of everything, right?
And which pump do I want exactly? I will eventually be at about 350-380hp. Currently at about 250.
Thanks
Anybody know why?
Thanks
