Badart
Senior Member
I have decided to freshen up the Hipo 273 in my 65 barracuda a little. Before we got it running it hadn't ran in about 20 years and it has some compression issues, but doesn't smoke. I want to pull apart the top end and check it out and pop in a new head gasket set anyway. I recently picked up a set of rebuilt 318 smog heads with the casting number of 4027163 for $80. LOL I couldn't pass it up. I know that all of the 318 heads had around 58-60cc combustion chamber, but what was it for the hipo 273 and how much compression drop will I have by going to the 318 heads?
I figure that I can take advantage of the rebuilt 318 heads and swap out to an aluminum intake, I have a couple to choose from and here are my options, Eddy Performer or Holley Street Dominator?
I will also be using a Holley 600 Double Pumper that I have laying around. I also just plan on running the factory 273 exhaust manifolds and exhaust. What are your thoughts? Here are the heads that I picked up.
