318 or 360 engine
I have some 318's here in San Diego.....less than a 2 hour drive. Are you replacing a bad 318 or do you need all the parts for a V8 conversion?
406 MAGNUM (Small block) CRATE ENGINE — 435 HORSEPOWER
Better make sure your taillights are working, because that’s all your competition will see when you drop
in a Mopar 406 Magnum Crate Engine. This 4.00" stroker engine generates a whopping 435 horsepower
and 470 ft.-lbs. of torque, and will quickly make believers out of everyone. It features big valve Magnum
R/T cylinder heads and stainless steel valves. Drop one in and let ’er rip. For maximum performance,
Mopar recommends the use of a 750 cfm Holley carburetor (P4349228) and 1-7/8" exhaust headers.
Specifications:
• Thermocycled Block Is Bored to +0.020" Oversize
• 4.020" Bore/4.00" Stroke
• 9.0:1 Compression Ratio
• Big Valve Magnum R/T Cylinder Heads
• Distinctive Mopar Cast Aluminum Valve Covers
• 2.02" Intake and 1.625" Exhaust Valves
• Heavy-Duty Valve Springs
• Hydraulic Roller Camshaft — 288°/292° Advertised Duration (230°/234° Duration @ .050") 0.501"/0.513" Lift
• Single Plane, M1® 4-bbl Aluminum Intake Manifold
• (Includes Bosses for MPI Conversion; Taller than Stock — Check Hood Clearance)
• Double Roller Timing Chain and Sprockets
• 8-quart Center Sump Street/Strip Oil Pan
• Mopar Electronic Ignition Kit with Distributor
• Heavy-Duty Engine Stand and Engine Crate
• Does Not Include Accessory Brackets
• Not for Use with A/C or for Factory MPI Installations
• High Volume Oil Pump
• Externally Balanced to Stock (Production) 1993–2003 360 Magnum Engine;[SIZE=-1]
[/SIZE]
[SIZE=-1]The Following Components Required for Proper Balancing (Not Included): - Flex Plate P4876706 and a Symmetrical,[/SIZE]
[SIZE=-1]Neutrally Balanced Torque Converter or Flywheel P5249842 Are Recommended (Not Included)
[/SIZE]
5153474406 Magnum Crate Engine — 435 Horsepower Magnum Block Thermocycled .020" Overbore
something bolt in and go or that you can rebuild to order? i have a 360 long block i'll let go real cheep if your looking for something to build. i'm in L.A.
chuck
I've got a fresh 360 long block with X heads if you could use it. Shipping is not a problem and I can help with that.
The picture shows it painted in prime and I'll paint it any color that you want.
Ken
Edison, NJ
I have a fully rebuilt one ready to go.It has 10,000 miles on it since rebuild. I was going to use it for my Formula but I am going with a 383....$800.00
i'll trade you the heads off your 318 for this 360 that i'm probably never going to use. i could meet you half way
chuck
