Hello everyone on FABO,
I was looking to get some input on an engine build I will be doing for my senior project this year. I currently have a 318 in my 75 dart that needs to be refreshed. I was going to base my build off of the zero deck build Mopar Muscle did. I am not aiming for crazy power but I would like to get as close to the 400hp they had going on theirs. Here is what I was going to put in,
Pistons:
Instead of the Keith Black ones used in their build I was going to order a Federal Mogul rebuild kit from summit that has Sealed Power cast aluminum pistons .30 over.
Cam:
I was going to use the same 280H Comp Cam used in their build
Heads:
Magnum heads
Push Rods:
Same comp cams ones used in their build
Crank:
Stock
Rods:
Stock
Carb:
I currently have a 4 barrel Edlebrock carb and intake on it that I was going to re-use for this.
I currently work at a body shop which is where ill be doing this with a little bit of help from my boss. This will be my first engine build so I was hoping to get some input from other people on this.
Thanks Dom
Pistons:
Cam:
Heads:
Magnum heads
Push Rods:
Crank:
Stock
Rods:
Stock
Carb:
Thanks Dom
