325-350 HP 360....is a stock mechanical fuel pump adequate?
Kern Dog
Build your car to handle.
Granite Bay CA
I need a fuel pump for a 1990 360 that will be going in my 67 Dart in a couple of weeks.
I have no dyno sheets for the engine but I'm hoping that it makes at least 325 HP.
1990 360, .040 over, KB 107 pistons, #308 heads. 9.48 to 1 compression. Air Gap intake, Holley 750 VS 4 barrel. Hughes cam .544 lift, 218/228 duration on a 110 LSA.
I've used stock fuel pumps in milder builds and never had starvation issues.
What are you using for similar builds?
I have no dyno sheets fort the engine but I'm hoping that it makes at least 325 HP.
Holley fuel pump on mine no fuel problems
The only thing I don’t like about the stock pumps is the reliability. I’ve had 3 carters go out in two separate applications within the past three years.
The most recent one was a failure at the pump to carb fitting that cracked/failed within a few miles of use. That’s in my 62 Lancer slant six where space is limited and it’s a bear to get back in there. Luckily the Carter carries a lifetime warranty at Oreillys where I bought it.
I’ve been considering the Holley/Edelbrock aftermarket options for the 5.9 in the Demon. I’d rather not swap pumps out every year.
Summit shows no listing for a Holley LA/Magnum mechanical pump but they do have them for the B/RB.
I saw this....
If the O'Rielleys have these, it would make things easier for any warranty returns...
I saw this....
My bad forgot it’s a Carter like you have shown M6866 had to go look on motor sorry my bad but haven’t had any problems out of it it seems to work fine
plenty adequate - some should have a regulator depending what pressure your carb wants -
I doubt any counterman would be able to tell if the 7 psi number is the max or what it is at all times. I've had many pumps put out 3-4 at idle and shoot up to 6 or 7 as RPM increases.
The Carter in a 440/495 pf mine idled at 11 ! For that, I did use a regulator and return line. It idles around 3.5 but shoots to 7 and stays there until I drop RPMs, just like a lower performance pump except that it returns everything over 7 PSI back to the tank. It absolutely cured the vapor lock issues I had.
This Dart currently has a 360 of maybe 280 HP and even with stock pumps, it has never faltered. 4.10 gears and off road drifting at 3000-4000 rpms and it has not stumbled or sputtered.
That's cause they ain't made here anymore. Guess where?
you'll be fine, if you are talking a 1/4 mile race anyways. I have a normal factory style fuel pump using the factory 5/16 fuel line and no issues. I too don't know what my actual HP rating is either, but it's gotta be around what you are suggesting. Both my duster and truck are set up this way.
If you can get a quality stock pump, I think you'll be fine.
A couple more data points for you.
My dad and I built a mild 408 for my Duster when I was in high school. It had stock 360 heads, 234/244 .488/.510 on a 112* LSA HFT cam, air gap intake, 1850 Holley (it's all I had at the time). I took it out regularly to Sac raceway on Wednesdays nights and ran 12.70s on 2.-something sec 60' times and never had an issue on the big end with the stock fuel pump.
The 340 currently in my '68 Dart had a stock pump for a while too and never had a fuel supply issue. It's got iron RHS heads, 231/.560/108* HFT cam, yada yada. Runs well for what it is - it's also run traction-limited 12's at the track with the stock pump. I only swapped fuel pumps when I replaced the front seal a while back because I had a 'better' mechanical pump on the shelf that I wanted to try. The only fuel system issue I've had since replacing the pump is a minor vapor lock issue solved with istalling a length of insulation wrap on the stock metal fuel line near the header.
ran a stock pump for years in my old yellow dart. IIRC according to the time slips the 360 was at around 350 hp. 12.20's in the quarter. never had any fuel supply issues.
No matter what is said about flow and pressure, too much is just about right. Put a pressure gauge on the car right in front of carb or fuel injection rail. And record it if you can?
If at ANY point in a run with a carb, the pressure drops below 25PIS in front of the pressure regulator (and that regulator better be in front of the carb somewhere) you ARE RUNNING out of fuel. I've proved this way too many times on different cars. On a 65 Dodge Cornet big block running low 9s, we found this out the hard way. After the fix, 35 PSI up to the regulator (down to 25 PSI midway 1/4 mile run) then regulated to 7 PSI big Holly Dominator,
picked up 3 MPH and 2.2 ET. 5/8 ID line to regulator (it was a triple bypass system) then -10 fuel lines to carb. (Think needle and seats opening and closing at least 20 tines in 9 seconds) Recording this proves this info.
FJB
