nm9stheham
On the balance question: For 2 grams, I would either not worry about it, or drill a little metal out of the piston pin area and make it the same as the originals. I have raced 6-7-8k RPM 4 bangers, NA and turbo, with simple piston changes with no issues or worries. BUT (and this note is for Bad Sport) make sure you also compare the pin weights if you have not done so already; they can change by many 10's of grams from stock Mopar to aftermarket. It is the total piston+pin+ring+ lock weight you are after for this case.
My point was that when you change piston type, like a big change in CR, or different piston style with the same process and material (forged, cast, etc.) OR change in material like from cast/forged (heavy) to hyper's (lighter), then the balance needs to be revisited 100%.
When you do your home balance for a V8, read up on how to weigh the rod's big end and small end weights. Balance the rod big end+bearing wieghts to each other, and then balance the rod small ends + pistons/rings/pins/locks to each other. The 2 rod end weights are handled differently in the balance process of the crankshaft. It is not that haed at all; it is a 'recipe' process.
A $100 eBay accurate gram scale+calibration weight set is OK to use for this for most engines that will not spend 500 laps at 7-9k RPM, IMO. It would not be adequate for NASCAR or Indy or F1.
