360 Combos
mikesduster
Winter Haven,Fla.
hey guys...most of you know that i sold my 340 out of my duster for some personal reasons and i now have decided to put together a JUNK YARD DOG 360 and NOT a 408"..
id like to know some of your combos and any little tricks that may help me get a little extra HP and TQ.
thanks,
mike
mikesduster said:
hey adam,
where did you find that list...it was VERY informative,.THANKS!!!!
Its from the tech archives. Found it doing a yahoo search one day.
Whats the shape of the short block ? If its running what I would do is clean it up, bolt on those Magnum heads that some one keeps offering you for free with a new set of R/T springs after redrilling them for a LA intake, Stuff in a Comp Cams 280H, a Performer RPM intake and a Holley 750. Then beet the crap out of it. Do you need headers ?
There are several core choices..I'd look for a mid 70s from a car or truck..Hear it run first, and bring a mechanical oil pressure gage with you. Aim for under 80K miles, but if it runs nice, and has good oil pressure (over 45psi at 3K, at least 10-15psi at hot idle and no noises) then a higher milage one will work too. I'd expect to pay around $400 for a good one. I would add as new parts: HV oil pump, pickup, pan (if its not a pass engine), cam kit, timing set, thin MP head gaskets, and an air gap intake. That should be about $900 in new parts, add another $70 for gaskets. so, you're up to $1370. A swap meet 750 Holley 3310 or 4150 and a kit for it should end up about $125 more. A curve kit for the distributor and timing tape, $20. Then the flexplate to run your convertor, $80. total= $1595. The "cam kit" is cam, lifters, springs, retainers, and locks for $450 because the 360s may have valve rotators that have to go. Cam choice depends on what the core has for compression and piston to valve clearance with factory pistons. I would also swap out the 8"stall convertor you have, and drop the gears to 3.91s to keep the trap RPM down.
Mike check out the June issue of Mopar Muscle. 452 h.p. from 365 CID. Good easy combo. With better heads...it will go over 500. Good luck. Terry.
