Also, are those numbers based on those boat anchor OEM starters from back in the day? The mini starter is a lot lighter.
Yeah and you don't share that enough.I would say it IS part of the problem. I have never scraped my headers on anything yet. El cheapo Summit headers.
You hush up. lolHey if you run your ride height high enough you can run any header you want and it’ll never drag. But I wouldn’t be proud of that or anything
Good point, I have both a 318 crank and 360 crank, I'll weigh them and see if there's a difference.The bigger main journal on the 360 cranks has to add some weight, and the longer stroke. Then x5 and you have a heavier crank.
