MR4V
Just about to buy the parts to rebuild my 360. This is what I'm looking at.
360 + 30thou, balanced.
Flat top pistons with fly cut or valve relief
Zero deck with 10.1 comp
J port heads with pocket port, 2.02 & 1.60
Roller rockers 1.5 ratio
Air gap with 750 hp Holley
130 GPH fuel pump
This is the first time this 360 will be milled & the heads have plenty of meat left in them.
Now I want to run mechanical flat tappet cam & the cam I have been looking at is a Comp Cam part number 20-247-4 with .495/.495 lift & duration @ 050 of 236/236.
What I want to know is if I increase the lift to one of the following what problems am I going to have?
Comp Cam number 20-248-4, lift .525/.525, duration @ 50 248
Comp cam number 20-230-4, lift .502/.511, duration @ 50 242
Comp cam number 20-231-4, lift .520/.540, duration @ 50 252
I will be running an auto & 3.7 rear
Thanks
130 GPH fuel pump
Thanks
