360 Question - 1989 in a Duster
74desertduster
Tucson AZ
Hey all,
Will a 1989 360 short block bolt into a 1974 Duster? Is it a roller cam engine or not?
Have a shot at a great deal on one but not sure about interchange.
Thanks
Brian
Yes, it will bolt in with the right pan and mounts (assuming it's a truck engine). It will have the mounting spot under the intake on top of the cam bearing bores for the roller lifter retainer and guides. I am not sure if it has the cam or not in '89.
I am picking it up tomoorow...the block is completely machined and ready to go...has stock pistons and crank.
Do I have to use a roller cam in it or can I use non roller heads and cam?
Thanks all!
Brian
no you dont have to use a hydraulic roller cam in it..
i have a mp crate shortblock...89 and it has a mp 508 cam in it.
