dkbug
Wrong or right, I've always used .006" per cc. A lot depends on the circumference/diameter of the chamber, so a .0005 or .0010 more adjustment higher might work better on a large bores.
I should add that I didn't use those numbers for a build, but more for evaluation purposes. Not a big fan of heavy milling. I'd rather use pistons to get where I want to go. :smile:
Spoken by someone with experience and I much agree for the most part.
