PlumCrazy26
Member
Recently I've been looking into building a 318 on a budget for dirt track purposes. I figured I go .030 over with a decked block and some 302 heads and I can run a relatively high comp. somewhat racey motor that will just squeeze under the 200 psi cylinder limit. However after talking with my dad I've become interested in the idea of the 360 bore'd down to 4.04 (340 piston size) where you can get the 360 torque with the bigger 340 pistons. I would love to build a 340 but they're few and far between up here in Alaska. SOOO without any further guff I'm curious what year 360 blocks will safely take the bore? Or if someone could point me in the right direction, that would be great! Thanks!
