imager
Subscribe to Thread: 360
Thanks for all the great info.....
Also got to looking at the connecting rods and the number on the side says 3418645 and as i search that number it bring up for a 318 and 340. Starting to think I have a mess on my hands here!!! Will those work in a 360?
Does anybody live near Karl? I'm really concerned for him, it's obvious someone has taken over his computer, and who knows what else. I hope he's okay. But whoever is posting thru his account, nice work there dude. :happy1:
Not to hijack but Krazykuda i reused the old bolts on the pressed-pin rods that came with my 360 when i rebuilt it. The cam currently in it tops out only just over 5000 rpm but i'm thinking of doing some bracket racing this summer; would there be a bad risk of me tossing a rod?
Karl, you're actually bein useful. I thought all you were good for was cutting the fool.
On the new rods Vs old rod thing, I have been told the new SCAT I beam rods are much better then the Eagle I beams. Not sure if the have the oil holes though.
Aaaaaand if I was computer savvy I'd post a pic of the car ha!!
Don't forget to>>>>>>>SEE PIC..... Or does this not apply to 360s???
Treblig
I''ve never seen that on a 360.
As I interpret your picture, it is looking down the distributor hole while driving the oil pump with a priming tool. Oil is spraying out of the plug and going onto the drive gear.
As far as I know the plug at the end of the lifter galley is solid with no hole? Where did you get yours? Or did you drill it yourself?
I always thought that the drive gear was oiled from the overflow from the lifter valley spilling onto it. I just looked at my block and I can see a path where the oil from the head should go down to the drive gear.
Would the hole in the plug lower the pressure to the rest of the oil system above it?
It looks like a good idea to have the hole, to make sure that the drive gear is lubricated, if it doesn't sacrifice oil pressure.
However, I've never seen or heard of a problem with the drive gear oiling.
Spent some time with those charts you posted up. Decoded my VIN,was quite fun. Also checked the oil galley plugs,yeah they don't exist on this block at all,makes me wonder. its hard to know what all this other person was doing. The plus side is it came with new Mopar Performance Stainless valves. Exhaust valve is 1.60" and the Intake is 2.02" and if i read correctly the 2.02" is what you suggested I used..from a 340? Found the numbers stamped onto my main caps and lined all anchor slots up. Still a very very long way off from actually putting anything together but I have been searching for parts. Mancini is simply wonderful,will be using them for sure. I have found some things on my block though that raises some questions. the VIN that you said is on the side reads 7D2425 5 and i thought that was a bit short and it doesn't seem to have more on it. Also I looked on the block by where the head bolts up for the other number and it doesn't seem to be there either .maybe just a lot of grime built up on it as it has been sitting and was passed along in the purchase. Sadly the only machine shop we have here isn't exactly what I would call a trusted machine shop as it is just our Napa parts store who is not well trusted in my parts. Any suggestions on a place that would allow me to ship parts to and from or any other suggestion on what to do? My notebook is filling up quite nicely from your information,I can't thank ya enough.
KrazyKuda, I found this pic under tech tips at FABO. It's a very good way to ensure your drive gear is well lubricated. The small .030" hole doesn't even phase oil pressure but it makes a tremendous difference to the dist gear. I know I've seen other folks with worn drive gears and people are always looking for better quality dist drives because they wear out!!!. This solves the problem with worn gears. You don't have to do this but it's very good insurance for your dist gear. I will make sure I do it to my motor!!! BEST OF ALL IT'S FREE!!!!! if you drill it yourself before you install the plug!!
Treblig
Seriously,is this guy even real?? Has to be a computer spouting off all this 360 information. No lie,I maaaaaaaay have taken a lot of this and started schooling guys at work (I do work in a shop but just simple brakes and suspension things,tires as well) and the look on there face when they hear what you've been teaching me. Take for instance the whole reason I made this thread,guy told me to scrap my 360 cause the caps weren't marked,even though he "builds" motors and low and behold,they are already stamped!!! Thanks for all the information,I have looked into the pistons and everything else actually,I cannot wait to get started with this build. Gonna be awhile,especially since my family is growing!!! Krazykuda thanks for the reserve on that intake,I pm the person. Hope too be able to post pics of me getting things done on the car. I recall a comment about "arguing" to see what cam to use. I'm ready to hear that argument,just let me get my notebook first
That's interesting. :supz:
Any idea what size hole it is? Maybe 1/8"? Smaller? Bigger? I wouldn't want to drill too big and loose some oil pressure. :sad1: ops:
It's only free if you don't break your drill bit drilling through the plug, which is not hard to do with a drill bit with that small of diameter.... LOL! :hmph: :banghead:
Too much lubrication won't hurt you as bad as not enough!! ;) :violent1:
Sorry, I just read and finally sunk in it's a .030" hole - much smaller than 1/8 (.125"). Very delicate drill bit....
THAT BRITISH HUMOR IS JUST TOOOOO MUCH!!!! I couldn't stop watching!!
On a serious subject, you simply drill the small hole in the plug before you install it. Then deburr the hole as required. Yes it is a delicate operation but if you drill it with the plug in a vise and you are careful the worst that can happen is that you break the drill bit (no big deal). You could also take a die grinder and grind a very small hole in the plug this way you don't break any drill bits. Actually once your carbide burr breaks through just the littlest bit you can take your drill bit and finish the job. If the hole only ends up being .020/.025/.030" it doesn't matter as long as you don't make it any larger!! If it comes out too big (no big deal) get another plug, they are cheap!! You can get a lot of oil to shoot out of a .020" hole under 30/40 PSI.
Treblig
