392 & 8hp70 65 Valiant
Make total sense. Only reason to really worry about the factory location is if you wanted to use a factory trans and mount. With the 8HP there is no reason not to put it where it is most happy.
Completely agree with wanting to keep the SRV function. Why pick a single plane or a dual plane if you can have both?
I've plan planning and collecting parts for a G3 swap into my '74 Duster for a couple of years now with the expected start of the swap being this winter. Then my son decided he didn't want his '73 Duster so now it is up on cribbing so I can install subframe connectors and torque boxes before I drop the front suspension and /6 out of it. Then I can cut the floor for the T56 and actually install the 5.7.
I currently have all the Holley swap parts, my V8 k-frame, (2) 5.7 cores, a 6.4 intake and cam, my T56 Magnum, several harnesses to cut down and (2) different PCM's that I could use. Really just need the time. Goal is to have the car on the ground and rolling before snow flies so I can get it to my Dad's shop where I can work on it in a heated shop.
My mother in law just bought a house in Rathdrum. Make sure to reach out if you make it up this way, love to see the car and I would buy you a beverage in appreciate for the opportunity. I love central Oregon too, maybe when I get my car done might end up down that way myself. My goal is to road trip the thing as much as possible.
Same, if your ever in the area do reach out. Sounds good, seems like a hemi swap in a newer abody couple be a little easier. But definitely still has its complications I’m sure. It may be a dream but I’d love to get this thing done and drive it to Hot August nights in Reno one of these days.
Got the MR Performance master cylinder adapter in. It kicks the master over all the way! Should do the trick. Need to still pull the pedal assembly out and modify the rest of it to work. Then we can get the adapter off to powder coat. Might need to go to a banjo bolt style brake line, it’s close but don’t think it’s touching.
is the brake pedal pushrod now "S" shaped?
No I’ve gotta move the pedal over, I’ll be sure to send an update when I get it out and mocked up. It comes with some chromoly tube to move the pedal, and then probably take the jog out of the pedal arm and make it straight.
I moved number seven coil to the firewall and ground slightly on the master cylinder to clear number 5 coil. I didn’t have to relocate the MC that way. You have flexible lines like mine so easy to unbolt, move over, and service 5 and 7 spark plugs. If that helps any.
I think I saw that in your build. I’d like to keep everything together the way it should be and would prefer to not have to unbolt the master cylinder to change plugs so this made sense. It’s a pretty straightforward install.
Got the brake pedal and master cylinder completed! Also got the heater tubes clocked, welded up and powder coated. Couple more things off the list!
Wow that looks awesome. Great job. The more I see this post the more I am like I need to Gen 3 swap my driver 65 dart lol. I still have not finished my other dart project haha.
It was time to mate the engine and transmission together! I will be running a “1320” converter with this build. I believe they are about a 2200-2400 stall? With the rear sump Holley pan I had to figure out a way to bolt up the converter. Just made a little alteration to the starter plate and it worked out great! Also got the brake lines ran after the first attempt was embarrassing to look at.
What are you doing for headers? Building your own?
Are the solid to flexible brake line supports of your own design or did you buy them somewhere?
So a big shout out to @Just Send It for letting me take his car trailer hostage! I just got the car to a friend in Washington to help with a lot of the fabrication work. He’s likely going to have to build some custom headers for it. I’ve got a set for a 67+ a body but it’s looking like they probably won’t work.
The brake hardware came from ArizonaHighTest they have a lot of nice stuff! If you don’t see it on their website but you do in their photos give them a call. They probably just don’t have it listed on their website yet.
