johnparts
Slammed 1
SO 5.7 Hemi sent me the factory harness he had and I spent the better part of an hour ID'ing connectors and labeling them does anyone have an idea of what needs to stay and what can go? I pulled a power distibution block out of a 3.5 charger with the plugs and relays so I will use that for my relay and fuse box but the harness he sent is quite obviously a truck harness. Also what do I need going to/from the pcm to make sure the engine works (running a manual trans so I just need the engine side not the trans side. I also need to know what the ALDL connector wiring needs to have to be able to hook a scanner to it. With all you guys being the wealth of info you are I'm sure I can knock this thing out in a day or so with the right info. Oh and I'm going to be running it all off of an 05 manual truck pcm program. Any help is greatly appreciated.
