R4Sedan
Larry
4k is a good deal, just make sure you are comfortable with him and his work!
I agree but be prepared for unknowns once the metal starts coming off.:banghead:
Yep, $4000.00 sounds like a screaming deal for nice work.
The 'Cuda ran me $9000.00....I am very happy with the result.
$4500 sandblast, prime, replace all 4 lower quarters, modify trans tunnel for overdrive, install hood scoop, paint, clear coat, wet sand. My friend owns the shop and I considered it a smokin deal.
I love that car. Hurry up and finish it already.
are they going to do the engine bay
..you really should look at some of his clients cars
..having said that my paint cost about the same and as already stated is similar to factory with fine orange peel..and i am happy
Hello, Do you know if they are using a single stage or a base clear coat? I work at a automotive dealership with an autobody. I paid $2300 for the base/clearcoat and primer for two coats.(supplies only) This was for the complete car,Under panels, Rims and interior parts. Too say the least i was a little shocked as this was supposed to be an internal price.
I don't know about you but we are regulated to use the wonderful water based paints. I think we still use a solvent based clear.
It looks like i will have closer to $7000. in my paint and assembly with myself doing most of the grunt work. Nothing is inexpensive anymore. Jason
I did mine for a few hundred bucks so to me 4k sounds like way too much.
body rate is $45-$50 an hour fyi
I mixed a gallon of glasurit 21 line (single stage now 22 line) today for my '78 Super Coupe, Probably $800 if you were to buy it in a store.
The Super Coupe would be a 7-10k job if I was doing it for a customer; disassemble car, have everything blasted except for the shell, repair minimal rust and lots of dents on every panel, prime/block ect... piant. Gonna start cutting everything in tomorrow.
I just made a list of what I need to prep a car for paint. This includes tape, masking paper, tac cloths,scotch brite, wax and grease remover, mixing cups sand paper and a gallon of 2K primer and activator. $600 in materials. No paint. No clear.
