4 speed swap
dartkid68
MI
ok guys im debating if i want to do big block in my 68 dart, will a big block 4 speed line up with the factory 4 speed hump? also what trans should i look for? thanks alot guys
Yes it will work. Did it in my car. Can give link to build if you like.
Bell housing you are limited if using motor mounts and mechanical clutch.
The transmission mount is the 'anchor point' for these cars. It matters not whether you have a 4 speed, 904, or 727, the rear mount / crossmember is the same, and determines engine position.
Man, O ,man are you gonna have fun. No auto can give the rush of the feeling you got the right hole 4 times in a row and under full power no less. Autos are for boys that cant play with there stick...
Four speed needs to have an A-body tail housing and main shaft to fit easily. Others have used B/E four speeds with special brackets for the shifter. I built the A-body 18-spline in my son's Dart using a '68 B-body 18-spline gears and an A-body main shaft and tail housing.
