I tried to answer this yesterday and got a paragraph and a half when I hit a button to make a sign and lost what I had types....so that pissed me off and I quit.
SO I will try it again.
After obtaining the new Brake Diagnostic Kit and some of the fittings and lines missing :angry5: ...called the supplier and they sent more fittings and lines. We hooked up to the brake lines and check pressures. Got pressures between 600# in the front and 700 - 800# reading at the rear "T"...to try to get to the calipers was a real feat. And they came in at 700#. The disc brake people said to make sure the rear caliper bleeders are level with the ground (they come and are installed at a 15 degree angle down).....so we took the rear calipers off and made sure they were parallel with the ground and re-bled the lines with the rotor bungee corded into place to have something to expand to. Things look better now but we are in another situation with the wheel spacer. (we noticed that the wheel is wobbling) so before we put everything back together....we are attacking this problem also. So we are in a holding pattern at the time.
"Bleeder parallel to the ground" doesn't sound right to me. I'm picturing only venting have the cavity . Set the calipers on top the rotor or somewhere with the bleeders pointed due north/straight up/ 90 degrees to the ground.. Open the bleeders and let it free bleed to remaining air out. No need to pedal pump bleed, just open the resivoir and keep it poured full.
