40 deg total adv ???? Hmmm
tooslow
lockport, Il
I am running a mopar 528 mech purple stick---Car is running good-no knock but I checkrd my timing and total is 40 deg all in at 2500rpm ???? Should be 36 deg right???
Is 40 to much total my initial is 16
440
forged pistons
all the goodies
auto 3000 stall
Mech dist
i ran 38 for a while no problem. only way to see if its to much would be at the track or on the dyno. since you have no ping or knock.
I run that in my SB 318 and it doesnt ping at all.
440
forged pistons
all the goodies
auto 3000 stall
Mech dist
Your at its max limit, go no more. have fun.
small bocks no more than 50, total.
You should beable to hear any ping or knock....better under load.What type of fuel you running?I run 94 pump gas.
94 pump gas
I apolagize i posted this thread in the wrong forum.
well" if it aint broke dont fix it" as they say. Put 1000 miles on her and some over 6K RPM ---- all is well
"Pinging" sounds like "steelie" marbles in your engine...it's a very distinctive metal knocking sound. Simply add 10* to what you have and take it for a ride....floor it and you'll hear pinging. Don't do it too long..... then reset your timing back.
