318 willrun has your answers, he's been working with a low compression 360, step by step he's at 12.8 et in the 1/4, it's not 400 hp but it's pretty respectable and very tame.
I had two different name-brand builders recently talk me out of building a 904 for my 408 project. They both said the issue comes down to the ability of the pressure to hold the bands/clutches so the trans don't last. One of them said they don't build the 904's anymore because of that. He said the 727's can handle the grunt much better and are less expensive to build. If just a mild street car the 904 should be fine with quality innards. It is when they are pushed hard that problems start happening.In 318will run's last post he has aquired a 904 with the later lo set first and second gears. In all the years i've been
on these forums it's never mentioned. I think this is one of the best modifications that could be made to increase
performance.I know a number of racers that run them.
Ok hold the phone;Thanks everyone. Im not going to race it. I just thought 400 could be an achievable number with lower compression. I should have mentioned it will have a 4 speed and 323 gears
100% you should build the powerband to where you want it to work best but if the engine not gonna be able to make the hp/performance you want in that powerband you need lager cid and or add rpm and or power adders.A set of aftermarket aluminum heads ( take your pick of the heads available) will have smaller combustion chambers and better flow along with less weight. So if they are in your budget they offer multiple benefits toward your goal. An aftermarket dual plane intake like the Edelbrock airgap, an appropriate 4bbl. carb of your choosing and a camshaft that puts the power solidly in the range the car will driven at are keys to getting the most out of your combination.
Choose your entire combination before you buy any parts. Consult with "experts" to be sure your combination is optimized and compatible with your goal then order parts.
Chasing a number might result in choosing parts that are too "big" resulting in a motor that might make the peak number but at the expense of power loss in the rpm range the car will be driven at with your choice of gear. Think of it like this, for every hp gained by moving the peak hp up out of the rpm range it will be driven at multiples of that hp will be given up in the rpm range you will use it most. Using that mind set might keep you from choosing parts that are too " big". Good luck with your project.
100%, some have it in their brains stock has most down low torque which a stock 2bbl 360 has 325-335 lbs-ft between 2,000-3,000 rpm and down hill after that I've yet to see a reasonably built engine do far worst than that.That "Other small block" video is excellent. For all those that think putting in camshaft will kill the bottom, there's little difference at 2500-4000 rpm across the board with all the changes, big differences up top. You get the best of both worlds. Put a 63 cc chamber alum head on that rated 8.5:1 360 and you get a decent squeeze factor.
Those 268 camshafts are mild and easy to tune throughout the operating range.
Say that's true how do make the most power there ? torque of course so peak torque at 4,000-5,000 rpm gonna give the most under 5,000 rpm power plus the most 5,500-6,500 rpm power for the few seconds your there.These posts always end up in the big hp, big cam, aluminum head quarter mile file.
Op is only driving on the street and the car will likely never see anything above 4000 rpm. 4500 rpm is 100 mph with his 3.23 gears.
You may never go above 4,800 rpm, but I do get and agree with what your saying, build it so it works best with how you drive and how you want to play with that power. Everyone is different and wants different things it's up to the OP to figure out what he truly wants.He may kiss 4800 briefly in first or second gear. Slam in a comp xe 250 and you will boil the rear tires at will and pin your passengers in their seats 'til well past highway speeds. Should produce 350 plus torque at 2000rpm and 400 at 2800 rpm. I'll bet it would be respectable in the quarter mile too!
I can hear the murmurs...
He's asking which cam and heads to run, so my guess he's open to aftermarket heads.I put heavily ported Edelbrock heads, RPM intake and custom-grind (.550" lift, 222° intake duration @ .050", 110 LSA) hyd roller cam on a stock bottom end 5.9 Magnum (9:1 compression) and it makes a verified 400+ HP (closer to 420). Might break 450 once I put Doug's headers on, better carb (750 DP instead of street demon) and upgrade the fuel system. It's very streetable, I drive it all the time.
What's my point? You won't make true 400 HP on a 360 with stock low-comp pistons unless you put good-flowing aftermarket heads (or heavily ported iron heads) and a high-lift (over .500") cam. Even with 10:1 it won't be easy if you're sticking with a street-oriented flat-tappet hydraulic cam and factory iron heads.
Shoot for 350 HP, that's much more realistic and plenty of power to have a lot of fun in an A-body.
That's the guy that got banned from here. lolKansas City Streets GoPro Ride Along 976 HP Brett Miller 434” W9 R3 Small Block Mopar 1968"
that's Mr. Brainy Pantaloons to you, sir.I did too. Smarty britches.
Where did the OP say stock heads, he's asking for cam and head advice.Ok hold the phone;
I have a 367 that by it's trapspeed is making 430 hp. I also run a manual trans but with 3.55s.
I know exactly what it takes to run 400hp. and I know,
yur gunna be sorry, unless you swap to 4.30s.
Here's why;
Your starter gear is 2.66 x 3.23= 8.59
Your rear tires are likely to be ~24.5 tall.
To make the 400 out of that combo, with the factory heads, my guess is that you'll need a cam of about 248@050.
The lowest rpm that your 400hp engine will sustain, with that cam/cylinder pressure, in gear, is gunna be ~650 and it will take a helluva tune to achieve that. Thus, the slowest speed you can ever drive is 5.5 mph; And with 400hp on tap, yur gunna need to be a hevckuva tuner, again, to not have the engine get jumpy on you down there.
So, forget parading. and you will be forever slipping the clutch, to drive any slower. And from every light and stopsign, you will be easing it out. Then, when you get to Second, the split is 72%, so say you are just driving "normally", like I do, lol, and you take First out to 2800....... cuz you know, you don't want to sound like a Mustang.
Ok so on the 1-2 Shift, the Rs will drop to 2000rpm........ and your big cam/low-compression/750/Torquer engine, is so far off the torque-peak, it will labor to get back up out of that hole, unless you give it lots of ignition advance, and then you get into detonation.
So then, IMO, you need to rethink the entire combo, else you are gunna end up like me with thousands of dollars worth of parts on the shelf, that did not work.
So again, IMO, you need to ask, a different question, such as,
"what would work with the parts I already have," or
state your budget and let the guys put it together for you.
But above all, state what rear gear you will not consider going bigger than; cuz those 3.23s with a 2.66low A833, are gunna be your limiting factors, for NON-WOT, First gear performance......... and every time the car stops, you are looking to drag yur azz thru first gear again which won't wake up until 3500@ 30 stinking mph, unless the tires are spinning, and that ain't gunna happen unless yur mean to the clutch.
IMHO
a good STREET build for the parts you have, and for your light-weight Valiant would be around 300/330hp.
300 for Iron heads, and 8/1 Scr
330 for alloy heads, new pistons at 10.5 or more, and maybe one size smaller cam.
I made 330hp with a 223/230/110 cam, and that was enough to take my 3650 pound Barracuda to 106 in the quarter, on street tires. Scr was 11.1 with those alloy heads.
I'm still not liking the 3.23s but I'd at least give them a chance. You better have a posi.
Happy HotRodding.
This will have enough grunt to pull that 8.59 starter gear;
You expect anything less?i love how the exercise was: 400hp with low compression, is it possible?
and here we are talking about gearing... and stall (when the dude doesn't even have an auto), and 1/4 mile times.
it's like OP asked for the weekend weather forecast and y'all are giving him recipes for cookies.
Cause some think everyone should build a car how they would and can’t see things from other’s perspective.i love how the exercise was: 400hp with low compression, is it possible?
today's 400 hp is yesterday's 300. lol400hp with low compression, is it possible?
well, duh. inflation!today's 400 hp is yesterday's 300.
that's just a different version of inflation...Every dog claims they have, 400, 500 hp when in reality they are barely making 375. lol
oh i fully agree! but it can be done with the right combo of parts, some shrewd exploitation of bits, seeking areas for small advantages, and throwing preconceived notions out the door.low compression is a major hinderance in making 400 hp N/A
Probably still the best answer.. Honestly if you have fabrication skills this is a cheap way to may decent HP/Tq with low compression & not a lot of $$$
Yea, he had a bad ego problem.Got banned,,really !
