400 automatic came with a cast crank, manual trans cars came with the forged crank. A 400 harmonic balancer doesn't have anything cast into it to indicate the engine size. The way to tell the cast type from the forged type is: cast balancers have an offset weight built into it because the engine is externally balanced. The forged crank balancers are symetrical...no weight....and are internally balanced. If you don't have the balancer, you can I.D. the crank by looking at the counterweights and how the crank was made. If there are sharp edges with rough, raised seams, the crank was "cast". If there are smooth counterweights and "ground off" looking areas but no casting seams, it's forged. Any decent machine shop should be able to tell.
