402 sb stroker > holley dp 850 jet sizes ??
stroker402
1968 dart GTS convertible
milwaukee wi.
say ... what are you guys running for jet sizes on a stoker sb ..have a 402 sb stoker magnum crate with a holley 850 dp.. jetted 81 front and 82 rear pv 45's ..50 cc pumps.. dart runs low elevens all day .. Just curious to see what You are all running on your strokers.. Tried all carb sizes and the 850 works the best . Imo
thinking about detuning for front carb for better streetabilty and fatten the rear jets up .. what do you think??
Thanks for you advice !
Jet it for best MPH at the track.
If you start to mess with big spreads in jetting front to rear, you run the risk of leaning out some cylinders.
If you do pull jet out of the front, the best method to get that area back is to increase the power valve channel restrictor size.
I think I will just set the 850 carb back to stocks specs . couple jets sizes smaller on each end. that will work.
