71swing
I really don’t mean to be a pain about it, I have asked a few other questions around it on other threads but this is slightly different. There has been allot of cam talk around the forums lately and it gets me double guessing myself.
Here is my dilemma. I have a 408 with Fast EZ efi, Air gap intake, edlebrock heads, TTI headers, 727 with valve body, 3800 stall Dynamic converter, 4:30 gears. Car will see more weekend cruise then it will track. Track maybe 3 times a year. Also keep in mind I will consult Dynamic after the motor is finished on a proper stall other than the 3800 that came out of my 340, which I’m sure won’t respond the same under the new 408.
I got recommendation before the build from comp for the cam linked below which I ordered and is on its way.
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=632&sb=2
BUT talking to someone at Comp Cams today they recommended the cam linked below. Now I’m conflicted if I have the right cam coming or if I need to send it back when it arrives for the other on below.
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=628&sb=2
What do you guys recommend? The 2nd smaller one is not too far off the MP cam (284/284dur. .484lift ) that came out of my 340 which I had originally intended to use, but decided to revisit the idea before the motor went back into the car.
Please help
Please help
