408 stroker build ??
sleepyhead416
Mcdonald pa
I just put together a 408 MAGNUM STROKER short block. I'm looking at my head options INDY EDELBROCK or EQ street strip motor 10.5 compression. What head are you running.solid or hyd roller lifters ?
2 set of eddy cnc by Modern Cylinder heads
1 set of eddy cnc by Hughes...
hughes flat tappet cams
Do Eddy's, ported by the shop of your choice, hydraulic roller.
Have fun!
CNC ported Indy/RHS, solid roller .640/.640 Lunati, this year. 10.7:1 Why run hydraulics, man?
I am running Indy 360-2's on my pump gas 394 ci. 10.9 comp. solid roller. 662 hp /533 tq on 93 octane.
408 engine, 1970 360 block, 360-1's cnc ported, solid roller cam. 6.29 at 108mph 1/8mile at 3,600ft of air.
[ame="https://www.youtube.com/watch?v=N5AG5ZT5SZI"]MRM 9 Ken Moreland and Shane Pulido - YouTube[/ame]
I have a 72 scamp street car, 3300lbs. Did a 360 magnum to 408 stroker with 10 1/2 to 1 and unported eddy rpm heads. Its a hydraulic roller with roller rockers and 750 cfm quick fuel carb. With 391 gears and a 3000 stall converter the car runs consistent 11.70's on pump gas with no ping at all on premium pump fuel and ran 11.10 the one time I tried my 125 shot of nitrous. Still very drive able too.
Pro comps are made in Australia .
I have a a set that are cnc'd and hand work with 2.05 I 1.625 e that I have not ran yet .
One of these years when I get the car together I will chime in on how they run .
I also have a set of edelbrocks ported by Laroy on my 340 and runs sweet !!
Still need to dial it in more .
I think any small block aluminum heads will do .
I'm curious about the victors ?
I see they are finally out .
How much power are you looking to make?
And that is the real question now isn't it?
Or, what is it your doing with your car? What's the target goal?
