416 questions
6dart9
I am building a 416 i have all of the bottom end on order and i am just waiting for it to get here.
The block is a 73 340 block and i need to know if it is going to need anymore machining on the bottom cylinder areas. My machinist did not know for sure and i was planning on putting the freeze plugs and painting the block this weekend but didn't want to if it was going to have to be machined. I plan on mocking it up once the parts arive but they won't get here for another 2 weeks.
So if anyone knows please let me know.
thanks
justin
Are you talking about notching the bottom of the cylinders to clear the rods? I used Scat I-beams with my 4" crank and they cleared with room to spare. Depends on the type of rods you are using. I believe h-beams and stock rods need some notches for clearance. The Scat I-beams use ARP cap screws which have a very low profile.
I wouldn't paint or plug it until after you have mocked up everything and require no more grinding.
Once you grind on it, you really need to wash it again in a tank.
Looks like the kit from Summit comes with I beams and ARP bolts. I will probably hold off until it all shows up just to be safe.
thanks
Yep just a little grinding for the bolts to clear the bottoms not a hard deal to do.
Pretty much any I beam rod will hit if it uses rod bolts. H beams use the cap screws (no nuts) and they should clear with no mods.
