426 small block stroker
I don’t but similar setups are 575-625 range. Has a Hughes roller hyd roller and they did Stage 3 porting on the Edelbrock heads
Hope you get that , I did not get close to that with the big mouth heads , but was runnning a stupid Air Gap intake ported but not enough , with your intake you should get much more than I did . would really like to find an intake like yours
What cam did you use? Just curious, gotta upgrade my HR cam this Season.....
Michael
It was custom grind from Hughes engines. Off top of my head it’s like .580 hydraulic roller on a 103 lobe separation. 235ish duration.
hm...if you get the cam Card can you please post the data? don´t think they put in a 103 LSA with EFI....but you´ll never know ;-)
Michael
Michael
They don’t. This cam was ground for the old combination I had which was stock stroke 340 with ported iron heads. But ultimately I never had enough compression for the cam. So when I switched pistons I also went for the stroker kit. When I emailed Dave Hughes and asked about the cam he said he would gladly sell me a new one, but to quote “try that one out first”.
It runs its *** off. I daily a hellcat and my *** dunno tells me it’s comparable. Not powerwise but the barracuda is a lot lighter than a hellcat.
but yes a wider LSA helps with vacuum which FI likes.
I drove the other day just to get a feel for it. It rips pretty good. Took some manual adjusting to get the idle right but so far so good. Starts right up and it’s constantly learning. It’s still cold here in Maryland so won’t go down the track for some time
Michael
here are the specs on my cam
lobe lift intake 0.377
exhaust 0.377
valve lift 1.6 rocker
intake 0.603 exhaust 0.603
duration @050 242.6
246.6
lobe separation106
centerline 102
cam timing
opensin 19 btc ex 53
What pistons you using? I had to order new pistons to raise the compression , the 23cc dish and 10.5 was not enough compression so I bought some 13cc dish pistons to raise compression a bit . just waiting to install them
They were custom. Came 11.2 compression with zero deck height.
I just did one just got it back from the machine shop but iam doing it with a procharger 20 pounds of boost I will let you no what it runs and scat does not make 426 stroker kit for small block 360la
My Uncle had one of them stage IVs in a Duster right from the factory. Biggest small block they ever made. Had a factory 7 speed behind it. And a Dana 95.
weren't those the cars that came with factory coil overs up front? My nephews uncle had one of those.
I wanted to do hughes' 426 kit.. but everyone screams don't go over 4" stroke... seeing these posts makes me wish i was going that way :)
it is a great kit with the right intake and heads i MADE 537 560 WITH THE WRONG INTAKE AND HEADS , WITH THE RIGHT HEADS AND INTAKE 600 would be no problem
I just want a solid 500 that i can beat the piss out of and not worry about blowing up :)
A good 408 can make 500+ hp around 5,800 rpm all a 426 is gonna do is make it sooner.
which is a good thing on the street.. also lower rpm=less piston speed less chance of failure i would think?
True but 5,800 rpm engine ain't exactly a screamer and a 408 already makes a bunch of low rpm torque.
