DTJ1989
Hello. I am new here but have been into cars for a while. I just completed my first rebuild on a 42RH in my 92 Dakota. I have one minor problem though. The shift mechanism will not move. I tried moving it by hand and lightly prying on it and it will not move. Any ideas as to what the issue is? I have a couple of my own. Either the manual valve got out of alignment with the tab from the rooster comb, the shift mechanism itself is jammed, or the parking pawl rod is jammed. The throttle valve lever does move and quite smoothly i might add with no pressure at all. Just checking all avenues before I put the transmission back in. Thanks in advance.
