430+hp 340 possibilities
Good mention! Race gas does not make your car faster if it doesn’t want it.
true….if it doesnt need it. If it does, it will make more power. Zero need to even debate this.
Let me know when you see a pro stock motor running pump 93.
Every one of Justins great running motors would be even faster if they were higher compression. Its a trade off not having to run high compression with the resulting race fuel required….its cheaper
The horsepower is in the heads and compression... find some W-2 heads and you will get there.
