QKFSH67
Had the engine built first time and the cam and lifters went bad during break in. Really couldn't pin point the problem because there were several variables. So started over this winter and took it to ship and had block cleaned and all gone through again. Broke in the cam, and I hear lifter ticking. Lunati hydraulic flat tappet. Cylinder number 8, intake side lifter had a hole wore in the.bottom of it. This is the same one that was really bad after the first build. Assume possibly plugged oil galley or ????thoughts please
