440- Engine oil dip stick
Big Block A body Tech
  1. No rush
    No rush Well-Known Member
    51
    5
    Mar 26, 2013
    Australia
    Local Time:
    9:00 AM
    Hi,
    I have a 440 and I have changed the engine oil dip stick to a Milodon 22070 (lost the one that come with it). Since fitting the engine to my 74 dart I have had to change the sump to a Charlie oil pan due to having an alterkation front end.
    I have only just noticed the Milodon dip stick doesn't have any markings on it.
    So how do I know how much oil to put in?
    Is there anyone I can contact or should I order a different dip stick?
    Thanks in advance
    Below are links the the sump and my original post.
    https://charliesoilpans.com/images/OilPans/Images/Pan14.jpg
    (74 dodge dart sump clearance)
  2. MoparMic
    MoparMic Well-Known Member
    167
    21
    Jan 22, 2012
    My Garage
    Local Time:
    8:00 PM
    I always put in what the pan manufacture says it holds and mark the dipstick. So in my 7 qaurt pan I put 7 in it and marked the dipstick which is at the add line on my Mr Gasket dipstick
    • Like Like x 1
    • Agree Agree x 1
    • famous bob
      famous bob mopar misfit FABO Gold Member
      14,939
      5246
      Aug 14, 2011
      okla
      Local Time:
      7:00 PM
      ^^^^^^^^^^^^^^^^^^^^^THIS
    • No rush
      51
      5
      Mar 26, 2013
      Australia
      Local Time:
      9:00 AM
      Thanks guys.
      Will try and get a hold of Charlie and see what they reckons
      Cheers
    • No rush
      51
      5
      Mar 26, 2013
      Australia
      Local Time:
      9:00 AM
      they said it all depends on what the engine builder wants.
      I would of thought no matter how big the sump is the fill mark would be the same?
      Any other suggestions?
    • forphorty
      forphorty Well-Known Member
      652
      235
      Jan 19, 2006
      Local Time:
      7:00 PM
      A deeper pan allows you to run the oil level lower. Benefits are less windage, less air being whipped into the oil and more hp .Example: If you have a stock shallow 4 quart pan, you better run 4 quarts in it. If you have a deep 7 quart pan, you can run 5 or 6 quarts in it and enjoy the benefits of the lower level while still having a greater volume of oil than stock.
    • No rush
      51
      5
      Mar 26, 2013
      Australia
      Local Time:
      9:00 AM
      In the end I just bought a stock 440 dip stick and fitted that.
      Filled the engine to the full mark and swapped the Milodon dip stick back in and marked it where the oil was.
      Haven't starter the engine yet, still a few weeks/ months away so fingers crossed.
    • Daves69
      Daves69 FABO Gold Member FABO Gold Member
      4,593
      2711
      Feb 20, 2011
      WestOfChi
      Local Time:
      7:00 PM
      Curious, when you filled to the full mark with the stock dip stick, did it come out to the pan capacity rating?
    • No rush
      51
      5
      Mar 26, 2013
      Australia
      Local Time:
      9:00 AM
      Charlie oil pans were very, very difficult do deal with and wouldn't tell me what the capacity rating is or even the size of the pan. Would not recommend buying a oil pan of them after my experience.
      Measured the dimensions of the pan and it came out to 11odd qts
      Ended up putting in 8.5L (9qts) and I think once I start it it will take an extra quart.
