Okay, about 6 years ago I bought some BB headers for an A-body off E-bay. I finally got my 440 done and am putting this all together. It all fits pertty well except the one pipe on the driver side that is near the steering arm. It rubs like crazy almost ot wher it wont steer. The question I had is with not knowing exactly what they are is there a trick to fitting them. (ie) do you need to buy a steering arm that is shorter? So they even make such a thing?
Supposidly they are hooker super comps for BB in an A-body. They are partial fenderwells in that on the drivers side 2 pipes run outside the frame and on the passenger side only 1 pipe runs outside the frame. Appart from that the others run inside the frame. i'm not sure if any of you have ever seen this style of headers before.
Any thoughts or should I just buy a set of full fenderwell headers and be done wtih it?
The motor is an INDY headed 700 HP Motor so I don't want to go too small or with Tri Y's.
Thanks guys!
Thanks guys!
