440 heads
racingsnake440
Anyone know what heads a 67 Imperial would have? 915s maybe or would they have smaller exhaust valves? Closed or open chamber?
thanks
If its a true 67 head then it would be a closed chamber with 2.08 and 1.74 valves. And if someone had changed them they could be newer but if it hasn't been apart my bet would be 72 cc's and 915 heads. The heads that came out the years before were called 300J heads and they look just like the 67 440 HP head but have a smaller exhaust valve and a much smaller intake port, and they don't flow anywhere close either. The 67 HP head has a 906 intake port as this was the first design for the 906 and the last of the HP heads and the closed chamber. Then the factory made a open chamber head for emission's purposes, this chamber was changed to the 906 and later open chamber design. The intake port wasn't changed until 72 and stayed this way until the Big Blocks were discontinued in August of 78. Also in 72 they flame hardened the exhaust seats for unleaded fuel's, as the eariler heads have to have the hard seats installed.
racingsnake440 said:
cool thanks
Caution racingsnake, I pulled apart 440's with 906's on one side and 452 and the other. Hell, I just did a 400 with a 452 on one side and a 902 on the other. The only way to be certain is pull both tappet covers and find the number, it'll end with a 906 or 452 or 902 or who knows. It's kind of like opening a christmas present.
And, 915s came with the small 1.60 valves and seats too. All depends. Never say "always" with Mopar. At least the small valve 915s donthave the bad core shift 516s have, so big valves and the bigger hardened seat rings are easy to stick in them.
