moper
Ink -
You asked for opinions. I assumed as Brian did this meant based on experience. We're only trying to help achieve your goal so take it for what it's worth. My apologies if mine differs from his but I think i'm more of a realist, and I've got enough real world experience to be able to say with conviction, it's not that easy.
As for the trannsy - I looked and the 60E is close to 200lbs with a convertor. I'm fairly sure a racey 904 with convertor is closer to 110lbs. I'm estimating adding the GV for another 40lbs. It's the total weight that gets you, and it's my belief that while that back seat 40lbs doesnt make much of a difference, the 40 (seat), plus another 70(trans), plus another 30(fenders), plus another 40(aluminum heads - would be more but that Ritter is heavy), plus another 40(moly over steel cage), plus another 80 (4link vs leaves), plus 100+ (modern disc brakes) all adds up as you make choices and build the car. Add in a huge battery, bigger fuel system, caging, maybe a radio and speakers, street wheels and tires, and the weight goes back up.
Regardless, a street car cannot react like a race car. Looking purely from a suspension point of view the best street car in the world can't 60' nearly as well as a purpose built drag car can. A drag race front suspension and tire combo will frighten you on the street when someone cuts you off in traffic at 60mph. And ask a bracket racer what the front end movement means for them.
What this adds up to is you need a lot more power to get ET from a car I would define as a street car. And when you are saying no boost, it gets much more blurry as to what will be "race" and what needs to be "street". That's my experience of 26 years and building all types of cars, not just one.
