So the White Whale leaks like the titanic on the way down. About 100 miles is a bit more than 1/2 qt of ATF. So I built this:
http://www.forabodiesonly.com/mopar/showthread.php?p=1970867769#post1970867769
here
http://www.forabodiesonly.com/mopar/showpost.php?p=1970864448&postcount=280
http://www.forabodiesonly.com/mopar/showpost.php?p=1970865329&postcount=281
and today got the mess outta there in about 2 hours, not bad for me, considering I spent 5 minutes laying on the ground crying after I ran my head into the differential "at full speed."
97 Ram 1500, 2wd, 5.2, 46RE leaking bad from the bell
So, take a look at the bottom photos. The converter is basically DRY. The front pump seems DRY, and there's a "one stream" leak down from the seal, PROBABLY done when I pulled the converter. it seems like??? it's coming from the lower edge of the front pump outer hub? Rest of it is pretty much dry!!!
More important, what would YOU do? Also, the pan is CLEAN, and from the paint on the converter, I'd almost bet this thing is a rebuild. PU has about 180K. Shifts and operates OK as long as you keep fluid in it.
here
