489 gear ratio help needed
discharger1332
silverdale wa.
i scored a 489 case with sg and richmond gears. all looks pretty fresh. but im not sure how to tell what ratio the grars are? i thought they would be stamped in but theese are the only numbers i see. any help is apreciated.
RICHMOND
4 82-7313-1 8620
If you can't find the gear ratio stamped on the ring gear, simply count the teeth on the ring gear and then count the teeth on the pinion, and divide. for example if theres 43 teeth on the ring gear, and 10 on the pinion, it would divide to 4.3 ( 4.30s) I hope this helps.
yea my richmonds didn't so i had to count the teeth
Go to Pg.5 for tooth count.
[ame]http://www.richmondgear.com/07pdfs/RGCatalogbody.pdf[/ame]
Counting the teeth between bolts and multiplying looks like 43 ring gear teeth, obviously just a guess. If thats true according to the chart it's a 3.91, 4.30 or 5.38 which i doubt. Really need to count both.
Nice score though:thumblef:
