Cuda416
Google it I just changed one the other day
5.7 rocker assy.... show me the rollers..
So your telling me that the lifter rides on the camshaft directly and there is no rocker arm in between the valve and lifter. So a roller that wears out on the rocker doesn't existNo, they do not....
apology I was getting the overhead camshaft Chrysler 3.6 confused they have the roller rockers BRAIN FART ...I'm saying you have no idea what you are talking about....
The roller in the fricking LIFTER has needle bearings which fail, causing the ROLLER on the LIFTER to NOT ROLL.... jezus...
I agree that would be the best thing to do. You might get away with just replacing the cam and lifters but the mds solenoids and vvt solenoids all have fine mesh screens inside that could be plugged up with fine metal debris from the wrecked cam. Not to mention what could have gone through the oil pump,cam and crank bearings.RJParts where 2500 and rest was labor. I told my sister in law to buy a long block and gasket kit, shipping and core charge $3800. I’ll replace it, she pays the core charge and I keep the motor and have it for a backup for when my 5.7 goes out in my Barracuda
4 to 6 week wait time. Have called 4 places, no crates available only 1 had a long block available. I even called modern Mopar extreme they have not crates just long blocks. Found 1 for $4500 with 3 yr warrantyDid a quick search last night, maybe these guys?
Dodge 4.7 Engines 3.7 2.7 5.7
Can’t find a crate available. Everyone I’ve called says only long block. Unless I get a crate for a car and swap the coverOrder a crate motor and swap it yo self
I’m a dealer tech so when we order a longblock hemi engine from Chrysler, we get a complete assembled engine, EXCLUDING coils,valve covers,timing cover,oil pan,mounts,flex plate,intake and exhaust manifolds. That should be all you would need other than the gaskets needed to swap those parts over from the original engine. Sometimes we can get a “ longblock dressed”. That engine comes complete from intake to pan.$$$$$$$. Would this compare to the crate engine you were looking at?Can’t find a crate available. Everyone I’ve called says only long block. Unless I get a crate for a car and swap the cover
This is what I do for a living since 2010 for a Chrysler dealer. Lifter rollers fail and seize up causing damage to cam lobe. Problem is all that metal has to go somewhere. First thing we do is remove intake manifold and remove and inspect the oil control valve. If it’s full of metal we don’t go any further. It will require a new engine. We are unable to properly clean and remove all of the metal debris from all the oil passages for the VVT system. Yes I know everyone’s Uncle Bob at the machine shop can fix all this real cheap but that’s not how it works at the dealership level. We have to be able to honor or workmanship or parts at another other dealership nationwide.My nephew has a 2016 Ram w/5.7 Hemi. He said it was loosing power and took to dealer and they told him it needs a new cam and rockers on the driver side replaced. Does this make sense. Why would the rockers be bad on one side and the cam. $5300 parts and $1800 labor
So what truck did you go to ?My friend's 2010 Ram 1500 had the cam/lifter failure too... dealer soaked him for ~$8000 (Canadian) for the repair. The second he told me that, I put my 2009 Ram up for sale and unloaded it.... it had the notorious "Hemi tick" already and I wasn't going to stand by and let Chrysler's shitty modern engineering bite me in the wallet.
At this point, I wouldn't touch anything with a Gen III Hemi in it.
The system definitely has its issues. But I’ve owned a Ram without MDS and got about 10 MPG. So I definitely helps. Especially the newer trucks with the 8 speed trans. I hate that they have these issues cause they are strong performing engines. Our trucks and cars are big and heavy and still run strong. GM has the same type issue with there DOD system. I wish they would spend the money on a better quality made lifter / roller bearing.What's all inside a variable displacement Hemi! From the top. A chunk of foam to camouflage the noise, then screens and more screens and now a magnet to colect the metal mush. Finally lifters practaly laying on their sides with limited availability to any oil splash/ windage. I'll leave this for anyone to ponder the thought that any of this is a good engineering marvel!
View attachment 1715756912 View attachment 1715756913 View attachment 1715756914 View attachment 1715756915
