5.7L hemi Duster/resto.
I started making some progress on my rear tri-4 link. Can anyone running 17or18" rear wheels get me a measurement from the top of the axle tube up to the frame? at ride height..
thanks for any help
Shawn
Got this today.
Hopefully the drive shaft hoop gets here tomorrow from summit and I can work on the rear cross member for the 4-link.
On the other side of things. Dose any one have a aftermarket damper for a 5.7 hemi? I'm looking for a way to attach the lower cogged pulley to the crank. By the looks of things the ATI pulley has bolt holes I could probably use just not sure if the pictures I see of these dampers are accurate.
This is the lower cogged pulley I have.
I have done a bit of research and am starting to think I mad want to go with a serpentine belt setup. Possibly a dual belt with a ten rib belt on the super charger...... Anyone else have a similar setup any input would be great before I start ordering parts
I think I can use the ATI super damper and possibly bolt a ten rib pulley to the front of it....
