slimjim
Ok, I know it is not an A-body but I figured being a 360ci you guys could help me. So Im having a problem with my 96 Ram 1500. I was driving down the road when the engine died. I pulled over to the side of the road and tried to start it up again, no luck. I then pulled a spark plug and checked for spark. thumbs up, theres spark. So it must be fuel right? This truck has never been messed with or modified. It is completely stock. Is there a way I can test my fuel pump to see if it is the problem? Any idea? I really dont feel like pulling my tank (just filled up at 4.19/gal...ON BASE) just to install the new pump and have the truck still sitting there not running. The truck only has 74k miles on it. All I have now to get around is my Ninja but the girlfriend WILL NOT get on it so i need to fix the truck asap. Thanks
