55 gal drum pump ?
1969Fish
Springfield, MO
Just switched over to alcohol and am buying a 55 gal drum. What pumps do y'all use? I've seen a lot of the plastic hand pumps which I think would be fine, I don't need anything fancy but I would like the pump to seal the drum when not in use.
What experiences do you all have with this?
And I figure I'll mix klots too lube in the drum. Does that settle? Does it have to be stirred?
Thanx
With respects Sir,
"The Pump" is a non issue :) , ...
Climate control for Alcohol in a Steel or Plastic (55 gal drum) 'is' :) :)
With respects Sir,
So leaving a metal drum on a pallet in the shop during the dog days of summer is going to ruin it?
I want the pump to seal the drum when not pumping as well. Do they all do that?
Make your own cheaper
[ame="https://www.youtube.com/watch?v=6_SqlItKbsw"]Amazing NEW AirMaster Drum Pump - YouTube[/ame]
Never considered a ground... I'm using a plastic hand pump...into a plastic jug.. Is this still necessary?
I use the plastic ones and always pull it back out so you can reseal the drum. Otherwise it will evaporate.
