64 barrcuda kick down linkage
Cuda 1964
Onaway Michigan
Hi there can anyone help me out would like some pics of original kick down linkage for a 64 barracuda 904 push button trans 2bbl 273v8 no air need know what is correct linkage thanks
Gonna be a 3 rod "Z" setup from the carb to a bar mounted at the the rear of the driver head that operates a vertical bar down to the the trans bellcrank and then the 3rd goes back to the kickdown linkage. The important part is the rear head bar that's a bolt on. The other rods can be fabbed from other models if needed.
Thanks pishta I have a couple of parts but don't know which one is original for that year
please note, the early linkage did not have a slotted connection for free throttle return. Update should be considered for safety reasons.
