BobW
Curmudgeon At Large
The bench seat in my Valiant was pretty much trashed, you had to close the door to keep from falling out!
Chrysler Sebring buckets are the right width and have integral shoulder harness'.
Found a set at the local wrecker from different years (based on the plactic trim) but with the same tan upholstery. Driver seat is power! Even got the matching rear seat thinking I could use it to recover the stocker. All in for $150.
Used 2x2angle across the front and made a spacer to keep it level1st pic, 2nd pic is bolted to the seat. Yes I know the wels are crp, but they are inly to hlod the spacers in place and keep the bolts from turning.
The seat will lift out just undoing 4 nuts from the bottom.
