That is going to be one B A ride !!!
Thank you. It has a long way to go though.
Not sure how I missed this thread - subscribed. I gave up motorcycles back in 86 when I was in and out of Walter Reed and Bethsda Naval Hospital after being paralyzed on one side from the chest down due to a disc imploding against the spinal column.
What intake rockers are you going to use? The mp ones are no longer in stock. I really want ductile iron ones so I can build a bullet proof vavletrain but the max wedge ports require more offset than a stock rocker has.
Subscribed and I know all about motorcycle accidents been in 3 to many my back is still jacked up from the last one. But get some rest and relax the car will be there when your ready.
im just starting to comply parts for my boosted low deck motor going in the toad. I havent started any posting yet I will once I start the mock up process.
Get well soon and happy holidays
Aaron
I will see this thread move again i follow you !
Great job Brad.. seal those puppies up to keep all that future tire smoke out of cockpit. .![]()
you might try stitch welding if ur using a mig, it`s slower but looks way better for an amateur -- not calling u an amateur tho .Thanks.
It's all sealed up now; rear axle, ladder bars, shocks, and rims/tires are all reinstalled. I now have 1.5" of room on each side of each tire with my 28 X 10.5 X 15 slicks. Once I get it on the road I'll start looking for some wider tires and possibly wider rims since my current street tires are 305 X 50 X 15.
Fortunately, all of those ugly looking welds will be covered up by carpet once I ever get to that point. I never claimed to be a good welder, I'm just hoping i burned in everything good enough to stay together.
can the rear seat be modified to fit?Primed and painted inside, primed on the outside. I still need to put the seam sealer on from outside.
