'65 Cuda Brake Pedal Assembly
biodude420
Member
Northern Calif.
I'm converting my 9" drums to factory kelsey hays and want to use new after market 1973 style 15/16" bore M.C. and power booster. Will my brake pedal bolt right up? how about brake lines?
Your brake pedal will be fine. You will need to buy the disc hoses and reroute new metal lines to a disc proportioning valve and new lines up to the master cylinder.
the proportioning valve and metal lines originating from it came with the set of kh's i bought. are these the only new lines i'll need? also, will the pedal rod fit okay?
