65 Cuda clutch need advice
Barracuda 65
Amarillo
I'm rebuilding my '65 Cuda with 273 V8, Original bell housing, and A833 4 speed. I want to install a new clutch kit but not sure about what to get. It has the correct setup now and worked perfect before I pulled it out but I do not want to to go back with a used unit just for safety sakes.
Can anyone advise the best way to go?
Brewer has the correct stock clutch.
I checked with them and they have been out of stock for 3 months and no known date for restocking. Any other thoughts. Can I go with the 10" they show from another supplier?
Nope. The flywheel is designed for a 9 1/2" clutch. Their clutches are 10" with a special scalloped pressure plate. They were designed for slant 6 pick ups and vans. You might be able to find one elsewhere.
Oh boy....now what do I do? Any other options rot suppliers that might have the correct set up?
You could try but probably not. It is a pretty obscure application. Try Rockauto maybe? Look up a mid 60's slant 6 van
Look up Ram Clutches, Transmission depot, Mancini, and Six States. Summit does not have anything?
Yes, there might be a Ram available now. Even a dual disc may be.
Which clutch did you ask Brewer about? The Ram or the Conversion clutch? Here's the Ram info. Thanks Brewer Performance and Ram Clutches- A new performance clutch for Early A's
