65 cuda- engine drop
barbee6043
barbee 6043
Shepherd, Texas ( SE Tx)
hopefully getting close to dropping in the 273 in the 65 cuda. last SB I installed was 73 duster 12 years ago! I know the engine bay is narrow, is it best to bolt on the exh man before I drop it in or is there good room to do so after i get it in??? these are correct 65 manifolds.
If foggy memory serves me right, you will have to remove the steering column if you drop the engine in with the exhaust manifolds on. That drivers side manifold is a real pain in the a$$.
Good luck!
I was thinking the right side manifold might be tough to get at. I knew the column could be maybe in way for the left one. it is a m s. thanks for the info.
my sytem is a chain hoist hooked to rafter in the shed!!! helps if SHE does some puhsing and pulling as it goes in! LOL
