65 Cuda Heater Motor
cv300g
Member
PA
The heater motor in my 65 cuda hardly blows any air. It just has no force behind it. Through the heater, defroster or Air Conditioner its all the same...very little air.
Is there something that can be done to fix the motor or does it just need a new blower motor.
If it needs a new blower motor does anyone have a source to buy one ?
I'll check in the morning but I believe that it does.
If it doesn't, then it's the blower motor resistor. If it does, it's the blower motor.
I checked this morning and it does blow at two different speeds ...Slow and a little bit faster. It may be blowing the way its supposed too. At the next car show I'll see if I can compare mine to another similar car...Dart, Valiant , Cuda. Thanks for your help.
Wouldn't there be some sort of odor ? There's no odor.
Not necessarily. Could be a very old nest, it the smell is escaping through the cowl vents.
I have had heater boxes absolutely jammed full of nest material, and you would never have a clue from the outside.
okay, thanks ...I'll look into that as a possibility and see if its a problem.
