Isn't that 65/66? I thought 65 was the last year for the wierd bolt angle and the 5/16 intake bolt size.No. All 273 heads had the same closed chamber design similar to the later 302 castings. Only difference in any 273 heads is the intake bolt angle change between 66 and 67.
Those are 920's I have a 234 and a 920 on my 273. Both are 66 heads but the 920 was also a 1967 head. Mike66 and 67 should be the 902 casting which is the better head.
I think 273 4 barrel heads have slightly stronger springs.
The '64-5 models generally used the 315 casting....the '66-7 models, the 920 casting, and the '68-9 models, the 275 casting. The 315's and 920's, with good high octane fuel, perform well on a 273. Their drawback is crack problems and pump gas ping problems. The 275 casting is open chambered and doesn't have any particular crack problems so it's better suited for a pump gas daily driver. Use the '72-4 version and you get hard seats too! The 273 and LA318 used the same castings in the same year but there were some crossover stuff that is the exception to the rule. I've had 315 castings machined from the factory for the '66 intake and 920 castings with the '65 machining! Maybe different plants got the new castings at different times and just kept using them until they ran out? Very weird....No. All 273 heads had the same closed chamber design similar to the later 302 castings. Only difference in any 273 heads is the intake bolt angle change between 66 and 67.
Correct but who in their right mind is going to resuse 40+year old valve springs? Get a new set to match the new cam!I think 273 4 barrel heads have slightly stronger springs.
That's correct for the most part....along with a different intake gasket.thanks guys ... I didn't think there was a difference but was unsure. The intake bolt changed between 65-66 as far as I've been told.
Intake gasket? please elaborate? I have not installed my D4B yet so would I have run into this?That's correct for the most part....along with a different intake gasket.
Thanks, Mark
