'67 318 LA First year question.
Copper Dart
West Palm Beach, Florida
Allpar has some very good info.
"The new, LA type 318 was brought out in 1967; the main difference from the 273 was its larger 3.91” bore. There could be some confusion over the two 318 V8 engines, one using the old A type design, the other using the lightweight LA type. According to Mark Koskenmaki, all 1967 A-type 318s came from Canada, while vehicles built in the US had the new LA 318. The A-engines did not last past 1967."
Question;
I have read that the first '67's LA318's had a better cam grind, different cc head and a floating wrist pin on the rod/piston. Still looking to confirm this info.
Am I missing anything?
Any collaboration?
Seems odd but it wouldn't surprise me.
P.S. I will be pulling an ORIGINAL 318 LA out of my '67 Satellite early next year for a freshen up and gasket replacement. I will post the pictures to document the R&R. That might answer some questions.
More info from an articleEngine Setup and cam Lifters Lift Duration
273 2 barrel through 67 Mechanical 395/405 240/240
273 2 barrel 68-69 Hydraulic 373/400 240/248
273 4 barrel Mechanical 415/425 248/248
*318 2 barrel 67 Hydraulic 390/390 244/244*
318 2 barrel through 88 Hydraulic 373/400 240/248
318 4 barrel Hydraulic 430/444 268/276
318 roller cam Hydraulic 391/391 240/240
340 4 barrel 68 man trans Hydraulic 444/453 276/284
340 4 barrel Hydraulic 430/444 268/276
340 70 six pak Hydraulic 430/444 268/276 (adjustable rockers)
360 2 barrel 71-74 Hydraulic 410/412 252/256
360 2bb 75-up Hydraulic 410/410 252/252
360 4 barrel Hydraulic 430/444 268/276;
"Mark DuVerger wrote: "The 273 rods are not the same as a 318, they measure the same and look identical but are lighter; all 273 rods are full floating rods, 73 and up 318s are press fit rods for the wristpin. The 273 will rev alot faster than a 318, or a 340." ".
I placed an * next to the questioned info.
