HMBCUDA
Hello All,
I thought i would through this Idea out there to the fellow A-body owners on the site and see if there may be a need/want for an "A-body Barracuda grill surround Repair Kit"
Here's Why I'm thinking this, (and thinking) Others may be in need.
It has taken me over the past several months,(4-5), to round up the hardware, and tools, (actually still working on the tools, I still have some Dies that need to be made), but hope to get into the machine shop next week.
I had to order a minimum number of hardware parts so I have lots extra, enough to rebuild several grill surrounds. I also need to get some tools/dies made to set the studs and squelch the rivets.
So am thinking, as long as I'm going through all this, I might as well make some extra and help someone else out there that might be in need.
These kit won't be free of coarse...putting lots of time & money into it so far, & not finished yet. AND still not sure If the tool will actually work because some are not made yet and I have not completed rebuilding MY Grill Surround! (But am 99.9% confident they will work)
When I Say "REBUILD" KIT:
1) Specially made replacement studs
2) Die/tool to press them into the various brackets that are on the grill surround (after broken studs are CAREFULLY removed)
3) All 6 different size semi-tubular rivets needed to assemble the grill surrounds (2) and also the (2) head light surrounds (this is if/when you CAREFULLY grind off the rivet backs and EVERYTHING is in pieces)
4) Specially made tools/dies to set the rivets (2)
PRICE...? $175-200
I know most will say why am I going through all this trouble, just pop-rivet everything, Micky Mouse the stud issue, etc. BUT that's not my style, I want mine as close to OEM as possible, 50yrs after the fact.
Thank for any responses!
Dan
PRICE...? $175-200
Dan
