dusterdoug
...the catch being stock wheel tubs. Or is it even doable at all? My springs are moved in to the frame.
Discuss...
Discuss...
Discuss...
They'll fit with the springs out of the way. Just make sure you get the backspacing of the wheels dead on.
Which drag radials do you have on your car?x2
I think 15x8 5"bs is perfect with the 3" inboard or offset shackles
wheel selection is limited
crown vic wheels (ground the center down to fit over axle)
Discuss...
If you put them on a 7" rim it's easier. An 8 or 8.5 rim makes section width wider.
http://www.forabodiesonly.com/mopar/showthread.php?p=1559522#post1559522
Check Zhandfull's car out. Springs in frame. It's tight. Trimming the fender lip will help.
Discuss...
